Can't get any output from the WiModem232 in my terminal - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: WiModem232 / WiModem232 Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=79) +---- Forum: Usage (https://www.cbmstuff.com/forum/forumdisplay.php?fid=81) +---- Thread: Can't get any output from the WiModem232 in my terminal (/showthread.php?tid=465) |
Can't get any output from the WiModem232 in my terminal - Michaeltrip - 01-29-2018 hi guys, Last saturday i received my Wimodem232 without oled. Had to order a DB9 to DB25 cable cause my computer only had a female db25 port. The cable came by mail today. So i could finally hook up my wimodem232. Set the terminal at 300baud, 2 stop bits, 8 data bits. But no connection and no output from the wimodem232 in my terminal. Tried 3 pc's with different OS'es but still no luck. Should i order a other cable? Or try other settings ? RE: Can't get any output from the WiModem232 in my terminal - admin - 01-29-2018 The terminal MUST be set to 8N1 (8 data bits, 1 start bit, and 1 stop bit). Remember that you MUST be using a MODEM cable, and not a NULL-MODEM cable! |
