D64 dumping + flippy - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: SuperCard Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=3) +---- Forum: Commodore 64/128 disks (https://www.cbmstuff.com/forum/forumdisplay.php?fid=7) +---- Thread: D64 dumping + flippy (/showthread.php?tid=249) |
D64 dumping + flippy - Bacchus - 09-29-2015 1) I am keen to be able to dump commercial game disks, but also make easy dumping of my standard DOS disks. From the "Simple G64" thread I realise that the purpose of the card is not the vanilla DOS dumping, but it would seem that this is also a quite valid use case. Unless I can generate dumps into vanilla DOS, I don't really know if the ripping actually works. That makes me quite sceptical throwing something more difficult it's way. I tried Splice, track 1 to 35 into a G64 and then read the G64 into a program that can handle them (http://style64.org/dirmaster) but I only got garbage. Is this not the same sort of G64? Is there a reason why this shouldn't work? 2) Also, how if the flippy code coming along? My drive is hardware modded by a company "another vendor of Flux level cards" so it should be possible to read the flip side as well. Any feedback on this? RE: D64 dumping + flippy - admin - 09-29-2015 You can only create .g64 images from disks that were produced using the INDEX mark to start/stop tracks (which is most all commercially distributed disks). You need to use INDEX (not SPLICE) for these disks. You can copy any non-index'd disks just fine, you just can't create .g64 images with these. This is something that I need to work on. The purpose of SuperCard Pro is not for converting disks to various image formats, it's for duplicating/imaging original disks. There is no support for reading/writing the backside of a disk directly. The disk has to be flipped over. The pull-down menu option is there, but the handler code has not been completed yet. It's not a high priority thing at the moment. |
