SCP Serial port support added! - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: SuperCard Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=3) +---- Forum: Latest News (https://www.cbmstuff.com/forum/forumdisplay.php?fid=2) +---- Thread: SCP Serial port support added! (/showthread.php?tid=169) |
SCP Serial port support added! - admin - 06-27-2014 Both SCP serial ports have been activated with v1.0 of the firmware. The default baud rate of the RS232-1 port is 250Kbps, and the default baud rate of RS232-2 port is 9600 baud. You can of course change the baud rate to anything between 300 baud and 1.25 megabaud. Changes to the baud are non-volatile, so a reset of the board will restore the default baud rates. If anyone thinks that either of these should default to a lower baud rate, please let me know. |
