ADF support! - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: SuperCard Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=3) +---- Forum: Amiga disks (https://www.cbmstuff.com/forum/forumdisplay.php?fid=8) +---- Thread: ADF support! (/showthread.php?tid=117) |
ADF support! - admin - 04-08-2014 SCP can now generate ADF images of disks, and even recover bad disks! RE: ADF support! - videofx - 06-12-2014 I am testing now! RE: ADF support! - videofx - 06-12-2014 My first disk works great! Thanks VERY MUCH FOR THIS!!!! Any chance we will ever be able to write the ADF back to floppy to create a disk? I tried and got an error. Thanks! RE: ADF support! - videofx - 06-12-2014 Just made an ADF of a disk I knew had problems and I got 2 half yellow blocks. Can I use this ADF? What does yellow signify? Thanks a million! RE: ADF support! - admin - 06-12-2014 Yellow means there were errors during recovery, but the image is fine to use. It's possible that the data was extracted successfully even though the sector checksum might have failed. Try the image. I am looking at making a routine for writing .adf's back to floppy. RE: ADF support! - grider - 01-02-2015 (06-12-2014, 11:30 PM)admin Wrote: Yellow means there were errors during recovery, but the image is fine to use. It's possible that the data was extracted successfully even though the sector checksum might have failed. Try the image. Any news on writing ADF's back to floppy? I have the latest software and firmware (I believe) and I do not see a way (selection) to choose an ADF image as the source... Has this been implemented yet maybe i'm just not choosing something correctly. Thanks, Mike RE: ADF support! - admin - 01-02-2015 There is no support for writing .adf format directly, but you can use the HxC floppy drive emulator software to convert an .adf image to a .scp image and write the disk that way. RE: ADF support! - grider - 01-03-2015 (01-02-2015, 10:24 PM)admin Wrote: There is no support for writing .adf format directly, but you can use the HxC floppy drive emulator software to convert an .adf image to a .scp image and write the disk that way. Don't have that so I guess I'll wait till the routine is finished. Thanks RE: ADF support! - admin - 01-03-2015 You can download the HxC floppy drive emulator software (it's free): http://hxc2001.com/download/floppy_drive_emulator/index.html Look under "software". RE: ADF support! - grider - 01-03-2015 (01-03-2015, 10:41 AM)admin Wrote: You can download the HxC floppy drive emulator software (it's free): Ooooh okay. Thanks, I thought I had to buy a piece of hardware like what you can get for the Amiga/AtariST as a drive replacement to do this. Even better I can just use software only! I'll download this and keep it in my arsenal of tools! Thanks again! Mike |
